Replacing right A pillar
Started 30th December 2017 at 11:21 · Guy Roelandts
Hi all,
    Was wondering if someone had experience with the replacement of the exterior (aluminium?) part of
the right A pillar. Any difficulty? Tha actual one is a bit dammaged and I’d like to replace it.
     Thank you.
      Guy
    • #10863
      David Wardale
      Hi Guy,
      From memory the trim on the “A” pillar is riveted in place, so you will have to drill out the rivets to remove the trim. I used small stainless steel screws when I put mine back together which worked out pretty well!
    • #10892
      hi Guy Roelandts ‍
      Are you referring to the Chrome Windscreen surround ?   If so, why didn’t you mention it before I came over to Belgium last week – I’ve got a spare I could have brought over for you !!
      As David Wardale ‍ says, these are riveted in place – they are easily drilled out and replaced by a small screw.  What you do need to be careful of is fitting, to make sure you don’t put a bend in it as you won’t get a crease out.
    • #10904
      Guy Roelandts
      Sorry I didn’t mention it before, I didn’t know you had spares available … now I know and will surely contact you before I try to source
      them from other locations. As I didn’t buy it yet, maybe I could wait till you come over again in the spring/summer period. I am not in a
      hurry to have it replaced anyway.
      And thanks to you and David on the comments on how they are fitted and how to remove them. I know we have to be careful with those
      type of parts, having replaced some of the same type on my TR4.
      Guy
