Gearbox clonking
Started 26th October 2018 at 20:42 · Geoff Pedlar
I get a load clonk when engaging reverse, both from park and neutral; and it also jerks the car. A quiet clonk with drive and no jerking.
Advice so far is to re-new the rear gearbox mounting. I’ve done that, with no difference.
Any thoughts gratefully received.
    • #14796
      Paul
      How high are your revs at idle? It sounds more like the car is trying to drive rather than the gearbox clunking against the transmission tunnel.
      • #15004
        Geoff Pedlar
        Member
        Hello Paul,
        Thanks for your thoughts. When cold the revs are a bit high, about 1100, probably the auxiliary air valve. when hot revs are correct at aroung 600.
        Sure the clonking is louder at higher revs, although still very much there when hot. Would that solution apply bearing in mind its only when putting it in to reverse ?
        I’d better get that air valve changed !
    • #14819
      have you ever flushed (cleaned) the gearbox ?
      it can lead to spectacular improvement.
      I had the same with my mercedes automatic after 120.000 km.
      after a quality flush, it was back to new.
      • #15006
        Geoff Pedlar
        Member
        Hello Gerben
        Well that’s an interesting thought. I’ve never changed the gearbox “oil” as it always looks so clean, and rarely have to top it up. Do Mercedes use the GM box at all, or are their boxes always their own manufacture ?
        Worth a try anyway.
    • #15023
      it is not about changing the oil,but a flush,to get all debris out of the very small canals and valves !
      changing the oil will not help at all.
      so my advise:flush/change filter/new oil.
      best regards
