Fuel tank related Q’s….
Started 27th June 2026 at 19:01 · Keith Thomas
What capacity is the fuel tank in a XJ-SC ?! Mine appears to be 60ltrs. At least, when I have twice run out of fuel completely that’s the amount I have subsequently brimmed it with. Seems ungenerous when compared to an XJS’s 90 ltrs ?
And re running out of fuel….is the  XJ-SC fuel gauge ‘float assembly’ (?) unique / unobtainable ? Does anyone have a spare ? My gauge never reads more than half full, but appears to be accurate for the lower half of the tank eg ‘fuel low’ light comes on. Now that I understand its foibles I will pay more attention to it !
Keith.
    • #26127
      Hi Keith,
      The XJ-SC Cabriolet was built on the basis of a nearly completed XJ-S Coupe, with the modification concentrating on cutting off the roof and also adding some strengthening metal work. The fuel tank as far as I’m aware, retained the original Coupe’s – hence why you can retro fit rear seats from a Coupe into a Cabriolet, complete with the rear seat belt mounting points being there ready for you to use etc.
    • #26144
      Keith Thomas
      Member
      The Jaguar XJS Handbook lists the XJ-SC fuel capacity as 81.8ltrs / 18 gals (as opposed to the XJS 90.1ltrs / 20 gals) but I definitely have 60ltrs from running dry at the side of the road to brim full……is the fuel pick-up dangling in the tank ?! Is it possible my pick-up is dangling only 2/3 way in the tank ?
      Anyone got a spare working fuel gauge float assembly ?!
      Keith.
    • #26567
      John Perry
      Member
      I bought afloat assembly about a a year ago from S G Barrett Ltd and oil pressure sender
      And if you put a 200 ome meter across the sender empty should read about 20 and full about 180
