- This topic has 8 replies, 4 voices, and was last updated 6 years, 10 months ago by Martin Ball (UK).
15th May 2017 at 13:02 #4617
The front alloy wheels get absolutely covered in brake dust on my car.
I once saw something mentioned that there was a disc that somehow when behind the wheel and acted as a dust shield.
Does anyone know what I’m referring to, whether they are any good at their job and whether it’s possible to source them anywhere.
Thanks in advance,
15th May 2017 at 17:53 #4625
I had them on my X300 as standard they certainly seemed to as when I used to remove the wheels for cleaning they were certainly fun of dust Never heard of them on the Jaguars. -
16th May 2017 at 18:10 #4642
Laurence, check EBay item numbers 111592541415 and 401314401692 as just two examples, other colours are available. As the brake calipers are set back from the hub face these can be fitted without any difficulty. They are not solid covers but have the drilled disc appearance and will certainly reduce the amount of brake dust reaching the alloys hence cleaning will be less frequent and easier overall. They come in pairs so you’ll naturally need two sets, cheap enough too 🙂
Let us know if you order some -
16th May 2017 at 21:45 #4645
Thanks John.
Thanks Mark, I’ve splashed the cash on a set to try – just got to wait a month for the slow boat from China to bring them to me 🙂
I’ll let you know how I get on.
17th May 2017 at 11:36 #4663
At that price I suppose it’s worth a shot, plus depending what Alloys you have fitted, the appearance of drilled and grooved discs through them will add a touch of speed from a visual perspective. What colour did you go for?
17th May 2017 at 12:19 #4666
The silver ones as we cheapest – just to see what they’re like. If they’re any good I might spray black if they don’t look right (but should be OK as silver)
17th May 2017 at 16:01 #4674
Certainly not what I thought you were looking for Mine were tin just slightly smaller in diameter than the inside of the wheel.
You placed them onto the wheel studs before you fitted the wheel, -
19th May 2017 at 10:01 #4696
Yes Laurence it would make sense to get the cheapest and in Silver considering most discs usually are that colour. It will be interesting to know how they perform and what your overall thoughts are when fitted. Please let us know 🙂
14th September 2017 at 10:01 #7933
I recently fitted these to my front wheels of my facelift and had to fit them so that the outer curved edge faced outwards, as if it faced inwards it fouled on the brake caliper.Their was not a lot of clearance from the brake calipers (about 2mm).
Unfortunately these did not stop the brake dust.
