oil pressure mystery
Started 5th January 2018 at 14:24 · Gerben Haringsma
ignition off , no oil pressure
ignition on, oil pressure at 5
start engine,oil pressure at 7
rev up moves out of scale.
cleaned contacts on instrument gauge.
changed sender unit to new one.
Visualy checked wires as much as possible.
any one,to help solve the mystery ?
    • #11094
      mystery solved !
      a resistor has to be instaled,getting the 5 back to zero.
    • #11096
      Hi Gerben Haringsma ‍
      While I couldn’t solve your problem, I do recognise the solution – on my XJS 4.0 litre coupe there is a mysterious tiny bulb in the engine bay, that when removed makes the oil gauge at the top.
      Glad you solved it.
    • #11100
      mysterious car,the jaguar.
      the tiny lamp was your resistor ?
    • #11276
      the resistor should be 15 ohm.
    • #11278
      sorry 150
