- This topic has 14 replies, 9 voices, and was last updated 6 years, 1 month ago by Gino Mariman.
11th May 2017 at 22:51 #4555
If you are feeling flush and after this scarce item go to EBay item number 311756920205
11th May 2017 at 23:26 #4556
Hello Mark
Thanks for sharing that link. You made me feel a lot better about the hardtops that I purchased for my two XJ-SC’s.
I bought two of them a few years ago from Paul’s Jaguar down in Ft. Lauderdale, Florida.
I needed one in Black and one in Dark Brown. Paul had only two left, one Dark Blue and one Black but they were both in really bad condition inside and out. I had to completely restore them both which was quite a job. I paid $ 785 for one and $ 595 for the other plus shipping. Then I had the costs for new outer padding and fabric, seals, latches, new headlining, and the cost to remove the glass windows and reinstall them on each one. I never added up the final costs once I finally finished them but know I didn’t spend $1,800 on each one.
Steve -
12th May 2017 at 10:25 #4562
Ouch that’s a lot of money, circa £1,400
12th May 2017 at 11:52 #4567
One of our members has one for sale Bargain at £1000.00 probably used twice– The problem is they are very fragile for transportation / Shipping. Also one of our members in Rome requires one but how do we get it to him any ideas?
By the way the Blue one on E Bay item number 311756920205 Has been on and off e bay for a long time. -
12th May 2017 at 18:26 #4580
Yes Steve, it’s always quite reassuring to know what the going rate generally is for such items and that what you may have assumed were potentially costly, were in fact reasonable, as it appears in your case:-)
Such items are desirable but as Laurence says, it’s a lot of ££££’s and unfortunately beyond my budget, even if it appears to be in nice condition.
The other one at £1000 sounds more reasonable, depending on condition, for as Steve pointed out, restoration costs are not cheap.
Hopefully there will be a way to help the Member in Rome. There are often small Transportation Companies who frequently cross to/fro Europe and the Mainland GB. Might be worth putting details about it on Anyvan.com to get some quotes. I’ve used this before to get a full interior set for a Lancia Delta Integrale from Germany to me here in Selby and it was only £220.00 all in!!
A wooden box could soon be knocked up from Lat and 5mm Ply to contain the Hardtop wrapped in Bubble wrap for protection -
17th May 2017 at 13:22 #4669
I just restored the hard top on my Talisman/Isis 87 Cab. The outer material is Haartz Cambria cloth and is still available. It is glued directly to the fiberglass shell with no padding. I pulled the window myself and reset it with
3M Window-Weld. I did both Targa panels also with new headliner material included, then pulled the windscreen and recovered the header section also so that everything matched… -
19th May 2017 at 10:06 #4697
You’re a braver Man than me Gary, especially in regards to the removal of the cars front windscreen. The hardtop window I might have had a bash, but not the main front one.
You make it sound quite easy, which I’m sure it wasn’t. What were the tricky bits? How long did it take you? -
17th April 2018 at 12:38 #12891
Has anyone any idea if I could purchase one of these hard tops now?
20th May 2018 at 15:29 #13281
Hi Peter my hard top in Black is for sale its in good condition and ready to fit on your cabriolet I bought it 4 years ago for my concours car but only had it on twice I paid £950 for it and it was in a jaguar box but the inner lining had drooped and latches were missing I put new lining and found new latches I don’t want to make money on it just get back what I paid if your interested please email me at brycabriolets@sky.com im also on facebook where you can see pictures of the hard top fitted to my car regards Bryan Thomas Leicester UK
29th May 2018 at 18:49 #13368Anonymous
Hello Guys ; my hard top in Black is for sale also. It is in verry good condition, but I live in the Netherlands….
You can write me on my email-adresse noort35@zonnet.nl.
Regards Frank
29th May 2018 at 18:57 #13370Anonymous
I still have a lot of items more: the softtop cover in Black and the 2 tops like new.
16th August 2018 at 18:10 #13931
Hallo Frank,
Je mag de softtop alvast reserveren voor me. Heb je net een persoonlijke mail verstuurd. Contacteer me aub op nr. 0032 485 16 80 80 Bedankt en tot snel, Gino. Ik woon in België 🙂 😉
29th May 2018 at 18:57 #13372
29th May 2018 at 19:41 #13378
29th May 2018 at 19:42 #13379
