Wanted- front parking light bulb failure unit DAC1908
Viewing 10 reply threads
    • #13231
        This failure unit is positioned near the auxiliary fuses behind a panel in the passenger footwell.
      • #13247
          @gerbenharingsma
          only available second hand,but cn be repaired!
        • #13249
            @gerbenharingsma
            only available second hand,but can be repaired!
          • #13250
              Not sure how they can be repaired as they look to be sealed,  maybe they can be bypassed which will only take away the warning light facility.  Has anyone done this?
            • #13278
                Looked a bit deeper and found it was a 3 amp fuse.  Whilst at it I have cleaned up all the the connections on the fuses/fuse holder, lighting relay and all other relays.
              • #13302
                  @gerbenharingsma
                  bypass is possible,but you will have to remove the dash light,as it will keep burning.
                  you an pry open the unit and replace the resitor wire,which is probably burned through.
                • #13304
                    @gerbenharingsma
                    would be most helpfull if one of the members with electronic skills could provide an alternative to this obsolete unit ?,?
                    anyone please ?
                  • #13312
                      I found a Company in the Netherlands that could supply one for €10 + €19 postage but the only way he would accept payment was by bank transfer so I declined doing this.
                    • #13320
                        @gerbenharingsma
                        which company is that Alan ?
                      • #13322
                          It is –
                          Jag parts & cars,
                          Schelluinsestraat 35
                          4203 NM Gorinchem
                          Nederlands
                        • #13519
                            @gerbenharingsma
                            thanks.
                            it would be nice if one of the members,could suggest an easy alternative..
                            it is no rocket science.unfortunately i have no clue of electronics…….
