Starting Issues '88 XJS 12cyl
Viewing 1 reply thread
    • #15339
      Gary Bonnell
      @garybonnell01
      Hello – my wife and I are restoring this beauty and the most recent issue is a problem when starting. We have replaced the usual suspects, and now the ignition. It still has an issue: turn the key and nothing. Try a few more times and it starts. Any thoughts on the subject would really help. Thanks, Gary Bonnell – Santa Fe, New Mexico
    • #15619
      Robert Gibson
      @bob-woft
      Hi Gary
      I maybe a bit late to comment on your starting issues but just in case you still have problems, my car would start after a few attempts, we would drive it out and back turn off the ignition and try to re start it to no avail.
      We replaced a relay (that wasn’t the answer) eventually we tracked it down to a micro switch near the base of the T Bar shift , if you pull the T Bar slightly out of park and the car starts then you need to replace that micro switch.
      Bob Gibson.
