- This topic has 3 replies, 4 voices, and was last updated 8 years, 5 months ago by Mark Thorley.
1st May 2017 at 07:49 #4103Laurence JonesKeymaster
Reading Andy Broadbent’s recent reply in another thread has made me curious.
What is involved in converting an XJS automatic to a manual beyond simply having all the mechanical parts? Is there engine set up and ECU changes involved ?
It is something I’ve been pondering doing for some time.
1st May 2017 at 17:03 #4112Andy BroadbentParticipant
This I do know – but for V12s only not for straight six cars.
V12 cars with the 6CU, 16CU & 26CU ECU require modification to the ECU to delete the fuel injector over run cut off. The 36CU cars do not require this modification – the revs drop between upshifts BUT the engine does not stall.
Rgds.
A.
11th May 2017 at 01:46 #4442Greg SouterParticipant
Thanks Gents
This is interesting , and I’d like your thoughts on an issue I am chasing , and whether this may be the issue.
I have a 9/87 XJSC with a manual 5speed in it, I have been chasing for some time, and annoying gremlin, that I wonder if the absence of the above modification ( I’m not sure whether its been done or not ) could be the cause of.
When driving lightly , and approaching a roundabout , or bend etc, and I back of the accelerator and ‘coast’ through or around bend/ roundabout, upon re- applying slight throttle, at the very first application I get an annoying miss/ hesitation / jerk from the engine, and then the car is off again, if I drive spiritedly around said bend / roundabout, keeping revs up with a blip of throttle and higher revs, no such, hesitation / miss / jerk occurs.
Could the absence of above modification be the cause?
22nd May 2017 at 00:19 #4800Mark ThorleyParticipant
Saw this company statement on an eBay Xjs item. Sounds like they have experience of carrying out Manual Conversions and worth a telephone call at the very least:-
“We have many other performance modification especially for the V12’s such as manual conversion, throttle bodies and much much more! Please see our other listings. Over 30 Jaguars in stock for parts. We are specialists in XJ’s!
For all enquiries please call or email the Simplyperformance team directly as it will result in a faster and more efficient reply. Jon@simplyperformance.com – 07796 002321 – Please do not message through eBay. If you do please leave a contact telephone number.
