- This topic has 2 replies, 3 voices, and was last updated 1 month, 2 weeks ago by Mitul Patel.
14th September 2023 at 15:07 #20376
I live in Potters Bar and bought my XJ-SC Cabriolet back in April (on a complete whim) and it needs a bit of work which I have been putting off. I would like to know if there is anyone from the club near Potters Bar who could help me get the car ready for an MOT so I can start using/enjoying the it? I have been told it is mechanically sound, engine fires and all the electrics work, just need to fit a battery and test everything.
The interior needs addressing, but this can be done as I come across trim/pieces and I need to find someone to reline the various headlining parts and replace the outer lining on the folding hood, targa panels and t-bar) but I need help fitting back the front callipers and bleeding the brakes (the previous owner replaced all four discs and fitted the rear callipers), replacing the front windscreen seal (I have a new seal) and give it a full check over for the MOT.
2nd October 2023 at 17:56 #20389
Hello Mitul,
I’ve just come across your post. I may be able to help or at least point you in the right direction.
I am on my second XJS restoration (and learnt a lot from the first). My current project car is also an XJ-SC V12. From my experience with the model, they all seem to rust in the same places. most of which qualify for MOT failure. I would be amazed if all your car needed for an MOT was the front calipers fitting…
I am in Epping, about 20 minutes from you. Please reply if you wish to get in touch.
Kind regards,
Curtis.
23rd October 2023 at 15:58 #20398
Hi Curtis
Apologies for the delay in getting back to you. Really appreciate you getting in touch. I have sent my contact details to Lawrence to pass on to you.
I have a small issue I need to fix…..my son tried to unlock the driver’s door using the only ignition key and broke it! I bought some blanks off ebay and had one cut but it doesn’t work. May have another go at getting another of the blanks cut but not holding out much hope. I have reached out to Jaguar Heritage to see if they can supply a key from the VIN.
Hope to speak to you soon.
Kind regards
Mitul
